July 19, 2018 at 3:43 pm
ewold
SubscriberHello.
I am running a 2 way FSI simulation and recently tried to decrease the element size in my fluid mesh. Before I did this, I was operating on a fairly low mesh resolution and everything worked as expected. Whenever I try to raise the resolution I receive the negative cell volume error. Is there a way to fix this without decreasing the magnitude of my load or decreasing the timestep?
Thanks
July 19, 2018 at 4:55 pm
karthik.remella
AdministratorHello,
Could you please clarify in which tool you are seeing the negative volume error - Fluent or mechanical? If you are seeing this error in Fluent, you might want to check your dynamic mesh set-up. Perhaps, the time step size is large. Or perhaps you are seeing large deformations (deformations should be smaller than one cell 'height' on a per-timestep basis). Does this happen at the beginning of your simulation (right after 1st r 2nd iteration) or during it?
Please post some more details (along with some images).
Thank you.
Best,
Karthik -
July 23, 2018 at 3:16 pm
ewold
SubscriberI was able to resolve the issue thanks to your response.
October 10, 2018 at 2:04 pm
Aparna
Subscriberi am also facing the same problem. how you resolved it. kindly help me. im simulating scroll expander.
October 11, 2018 at 4:49 am
Aparna
Aparna
October 11, 2018 at 9:46 am
Forum ModeratorYou might be better served by starting a new thread and including images of the geometry & mesh.
June 20, 2020 at 9:55 am
FarhanMuhib
Subscriber@ewold, can you please help me solve the problem? I am having the same problem. Thanks
- The topic ‘Mesh sizing leads to negative cell volume’ is closed to new replies.
