December 4, 2019 at 11:49 am
xiaoling
SubscriberÂ
Hi, I am confused that my mesh metric indicated none. It should not happen, right? My Ansys version is 18.2.Â
By the way, this is the only way to access mesh metrics, right? In the previous version, as I saw online, the mesh metric tool exists in the statistics part, and there should be a list of parameters under it.
December 4, 2019 at 1:28 pm
Forum ModeratorClick on "Mesh" in the tree and then scroll down the list. Note, the panels were redesigned a couple of versions back so make sure you check all the menus.Â
You want to look at skew, aspect ratio and (potentially) orthoganal skew/quality (the name varies).Â
December 5, 2019 at 7:50 am
December 5, 2019 at 8:09 am
xiaoling
SubscriberI finally got it!!!! Thank you Rwoolhou!
- The topic ‘Mesh Metric Help’ is closed to new replies.
1598
1386
1242
