May 4, 2019 at 8:52 pm
madhavair19
SubscriberHello,
When I am plotting my velocity contour, I can still see my mesh in contour plot. It is hard to analyze the contour with the mesh in display. Kindly help me to fix this.
Thank you!
May 7, 2019 at 10:45 am
Forum ModeratorHave you also picked "Display Mesh", left side of the panel in the radio buttons?Â
May 11, 2019 at 2:26 am
madhavair19
SubscriberNo. I have not picked that. It is unchecked.
May 13, 2019 at 11:05 am
Forum ModeratorIf you're in 2d don't select any surfaces.Â
Can you post an image as that'll help! It needs to be in line with the text as staff cannot open attachments.Â
May 15, 2019 at 5:20 am
madhavair19
SubscriberYes. I am working in 2D; and selecting no surfaces worked. Thank you !
But, what to do if IÂ want to select a particular surface ? Also, what is the way to correct this if I have a 3D model ?
January 11, 2021 at 10:18 am
nitishsharma
SubscriberArraymay be my problem is similar, i am also not able to see mesh , when i select meshplot .nArrayn -
January 11, 2021 at 11:04 am
Forum ModeratorI can't see the image: we're not allowed to open links. nFor mesh plot pick what you want to see in 2 and 3d. For contours etc in 2d pick nothing, and the surface(s) of interest in 3d. n
Viewing 6 reply threads
- The topic ‘mesh is visible while plotting the contours’ is closed to new replies.
1311
