TAGGED: fluent, fluid-flow, interface-boundary, mesh-interfaces
October 27, 2021 at 11:39 pm
kashfia.mahin
SubscriberI have created geometry in Solidworks and transferred it to Designmodeler.
October 28, 2021 at 11:06 amRob
Forum ModeratorIf you've already got contact_region_100 picked what are you setting?
October 28, 2021 at 2:06 pmkashfia.mahin
SubscriberThanks for your reply.
even I choose the name contact region 100 and I want to set it to be the coupled wall, it is showing the same error.
October 28, 2021 at 3:41 pmRob
Forum ModeratorWhich version are you using? If you pick the interface pair and pick coupled wall but don't press create does the option stick? We've changed the panels over the last few releases so it's more automated but then marginally more difficult to alter afterwards.
October 28, 2021 at 7:38 pmOctober 29, 2021 at 11:23 amRob
Forum ModeratorThe auto create functions weren't always reliable in older versions so I'd suggest either updating (2021R2 is v22.2 in old terms) or manually creating the interface zones. I would expect you to be able to pick the interface label and change settings though.
October 29, 2021 at 12:17 pmkashfia.mahin
SubscriberSir, I have a question. How to pick the interface label and change settings?
October 29, 2021 at 1:34 pmRob
Forum ModeratorYou have it selected above, just pick the coupled wall and then move onto the next label in the list. Then go back to the first to check the change was retained.
March 19, 2023 at 1:30 pmSyed MustafaKhadri
SubscriberIam using ANSYS V16.0. I too have similar issue. I want to create interface zones manually. After picking coupled wall option, i said create. Then it is showing error: Please specify name for interface in Mesh Interface field. Please let me know, how to sort it out. Thank You Sir.
March 19, 2023 at 1:33 pmSyed MustafaKhadri
Subscriberand also please show how to change the settings.Tq sir
Viewing 9 reply threads- The topic ‘Mesh Interface to Coupled wall’ is closed to new replies.
5664
1890
1419
1304
