Preprocessing
Preprocessing
Mesh generation of a rocket nose cone
    • Mario95
      Hello everyone,
      I have been getting some troubles to mesh the tip of a rocket's nose cone. I need to run a  3-D CFD simulation with turbulent flow at supersonic speed and I cannot get a good quality due to the tip of the cone. I attach some picture of the geometry. Thanks for the help.
    • Keyur Kanade
      There are certain videos on youtube about hex mesh for airfoil.
      use similar strategy for this model as well.
      you can use symmetry instead of full model.
      Keyur
      If this helps, please mark this post as 'Is Solution' to help others.
    • Mario95
      Is there a way to make a structure mesh out of it?
    • Mario95
      If I do symmetry I will not be able to model angle of attack because the flow will not be the same in both symmetry planes right?
    • Keyur Kanade
      if it makes angle to y axis only then symmetry can handle it.
      Keyur
    • Mario95
      Perfect thanks for your time
Viewing 5 reply threads
  • The topic ‘Mesh generation of a rocket nose cone’ is closed to new replies.
