Ansys Free Student Software
Mesh from spaceclaim
    • Venkata Subramanian M
      Sir/madam can you please tell me about how the mesh from the spaceclaim is transfered in model for analysis. After meshing in space claim when i open in model it shows meshed object only but the mesh nodes and elements are not transfered. The mesh shows in update condition. what should i do for this problem.
      Did you use Save-as and then pick a mesh format?
      Sir can you explain which format i want to save in Ansys. And which format i want to extract in model clearly
      Which solver do you plan on using? Then check the Help to see what formats that solver reads, and save to suit.
      Thanks for your reply. I am doing explicit analysis in Ansys workbench using SPH solver method then what format i want to save and then extract in model. Can you explain sir?
      I don't know, what does the User's Guide say?
      Sir can you please send the user guide link it would be helpful for me
      https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/main_page.html
Viewing 7 reply threads
  • The topic ‘Mesh from spaceclaim’ is closed to new replies.
