Preprocessing
Preprocessing
Mesh fail to intialize
    • pullah08
      I am doing IC Engine analysis and when I am trying to generate mesh these errors are showing up-
      Mesher failed to initialise.
      One or more non-sweep-able bodies have sweep method controls and cannot be swept.
      A body cannot be swept because the source and target faces are adjacent.
      For more reference I am attaching this picture-
      problematic geometry is shown
      so anyone please tell me how to cope up with problem?
      Did you set up the mesh methods?
    • pullah08
      I am not able to understand are you talking about this-
      The error is caused by a sweep method being assigned to a volume: did you set the sweep methods up?
    • pullah08
      No it actually came by default
      Not sure as I don't use the IC tools.  Check how it's picked the source face(s) for that volume: you need a source & target at each end of the fluid region.
    • pullah08
      Thanks rwoolhou
      I will try to solve it on my own
Viewing 6 reply threads
  • The topic ‘Mesh fail to intialize’ is closed to new replies.
