March 27, 2023 at 4:38 pm
March 31, 2023 at 3:07 pm
Sahil Sura
Ansys EmployeeHello Deniz Orta,
For viewing mesh with the body color display style, the following steps might be helpful. Please do check the image too which highlights the steps.
You might want to change the Color for the respective geometry from the 'Graphics Properties' section of the 'Details' window.
On meshing the geometry, you might see the default color.
You can also change the color to the respective setting by going to the 'Edge' section of the 'Display' Tab and selecting the 'Color' option.
There you can set the color according to the mentioned options and check the mesh.
Hope this helps!
Thanks,
Sahil
/forum/forums/topic/guidelines-for-posting-on-ansys-learning-forum/#latest
- The topic ‘Mesh Display Style’ is closed to new replies.
6625
1311
