March 17, 2021 at 7:42 pm
psayasith
SubscriberHello,
When I change the element size for my mesh from 2E-4 m to 1E-4 m I get this defeaturing issue. The bottom image is 1E-4m; I thought the smaller element size would increase the amount of detail instead of truncating my volume. The element size in my body fitted cartesian was the only thing I changed between these two. What could be causing my mesh to do this?
Thank you
March 18, 2021 at 2:46 amKeyur Kanade
Ansys EmployeeSo you are saying as you change element size, geometry is changed. This is not possible. nPlease check if you have changed the geometry in SpaceClaim. nOr please check if you have any section plane on. Please switch OFF section plane. nPlease go through help manual for more details nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student CommunitynMarch 18, 2021 at 1:26 pmMarch 18, 2021 at 2:32 pmRob
Forum ModeratorHow big is the geometry? Ie domain length and channel cross section. nMarch 18, 2021 at 4:32 pmpsayasith
SubscriberZ axis is 46 cm, x is 1 cm and y is 2 cm. Each channel is 1 cm by 1 cm. nMarch 18, 2021 at 6:39 pmpsayasith
SubscriberI misspoke, the z axis is correct, but the channels are 0.5 cm by 0.5 cm. I gave the dimensions of my model as opposed to the volume. nMarch 19, 2021 at 3:31 pmRob
Forum ModeratorCan you check you changed the size setting and not the defeaturing setting? Please double check the dimensions in Meshing: mm and m can get scrambled if you imported the model from CAD. nMarch 19, 2021 at 8:36 pmMarch 23, 2021 at 3:20 ampsayasith
SubscriberI haven't received a response in a few days, so I'm bumping. nViewing 8 reply threads- The topic ‘Mesh Defeaturing when Decreasing Element Size’ is closed to new replies.
6485
