Mesh Connection Group
    • Evgenii_K
      Hi guys, I am merging the shell and the beam using the mesh connection group, after merging the beams rotate and ANSYS gives the error - The Quad Mesher failed on one or more faces during mesh connections. I ask for help how to solve this problem !? When merging, the geometry should not change, but mine does.
      Model before unification:
    • Aniket
      Do you absolutely need to merge the nodes? Can you use MPC bonded contacts instead?n-AniketnHow to access Ansys help linksnGuidelines for Posting on Ansys Learning Forumn
    • Evgenii_K
      Do you absolutely need to merge the nodes? Can you use MPC bonded contacts instead?-AniketHow to access Ansys help linksGuidelines for Posting on Ansys Learning Forum/forum/discussion/comment/103017#Comment_103017
      Thanks, I will try to do it, but I avoid contacts because of the large model.n
    • Evgenii_K
      I connected the shell and the beam using an MPC contact and this is what I got. The picture shows that gaps appeared on the edges, but the connection remained at the verticesn
  • The topic ‘Mesh Connection Group’ is closed to new replies.
