Mechanical Materials Pane out of place
    • ahmetunal
      Copilot said:
      I understand this is may not be the correct place to ask this question, but could not find any other forum to post my question.
      I'm experiencing an issue that has been occurring almost constantly lately. I'm not sure what triggered it, but the Materials and Scripting panes no longer appear in their default locations. I'll try to attach a screenshot to illustrate the problem.
      Initially, I was able to resolve it by deleting the ANSYS folders in the %AppData%Local and %AppData%Roaming directories, which reset the layout. Unfortunately, that workaround no longer works.
      It seems that DSBrowserService.exe may be storing the layout information somewhere else, and I have not been able to identify where that data is saved or how to reset it.
      Has anyone encountered a similar issue and found a successful solution? Any suggestions would be greatly appreciated. Thank you!
      In Mechanical, on the Home tab, use the Reset Layout button and on the Display tab, use the Viewports button to select One Viewport.
