January 7, 2022 at 9:23 am
Mav14
SubscriberDear community,
I have one question about ANSYS Mechanical APDL: How I can get results from self-made nodes? I create the nodes with the "nkpt"-function before the meshing. But after the solving I can only read the results of the automatic generated nodes. For my self-made nodes I get the message "Requested data is not stored for node...".
But I need the results of the exact coordinates! This is why I create nodes by myself. I know the function to find out which node is near by the wanted coordinates but the different in the location is too high. If I cannot readout my self-made nodes the whole simulation is useless for me. ?
I hope you can help me!
January 7, 2022 at 12:03 pmVigneswaran Sridharan
Ansys EmployeeHey I suggest you make use of 'Selection Logic' in APDL scripting. Make use of commands such as CM (ansys.com), NSEL (ansys.com), CMSEL (ansys.com) while applying appropriate loads and boundary conditions.
Selection Logic ÔÇö Lesson 6 - ANSYS Innovation Courses - This AIC lesson should help you get started. Also, you might find relevant lessons in this 'Intro to MAPDL Scripting' course.
Vigneswaran
Ansys Help
Ansys Learning Forum
January 7, 2022 at 3:11 pmMav14
SubscriberHey visridha thanks for your answer. I look at your tips but can't see my mistake, maybe because my brain's not working today. You can see an extract of my MAPDL-Script below. Can you see my mistake and maybe help me, please?
!----Self-made nodes----
K,201,radius,0,1.5e-3
NKPT,201,201
K,202,radius,0,-1.5e-3
NKPT,202,202
!----Mesh----
ESIZE,netzEG,0
MSHMID,2
VSWEEP,all
VSYMM,z,all
EPLOT
!----Force----
NSEL,s,loc,z,hoehe/2
CP,1,volt,all
*GET,node1,node,0,num,min
F,node1,amps,strom
NSEL,s,loc,z,-hoehe/2
D,all,volt,0
ALLSEL
!----Solution----
/SOLU
ALLSEL,all
SOLVE
!----Auswertung----
/POST1
/PLOPTS,minm,0
PLNSOL,volt
*GET,spannung,node,node1,volt
*GET,spannung201,node,201,volt !ERROR: 'Requested data is not stored for node 201.'
I would be very grateful!Viewing 2 reply threads- The topic ‘Mechanical APDL: How to get results from self-made nodes’ is closed to new replies.
6520
1311
