Ansys Products
Ansys Products
Mechanical APDL GUI not showing Main Menu
    • Ankanish
      Hi there, I am using Mechanical APDL on a university desktop. When I open the GUI, I cannot see the main menu or command line. I don't know the exact reason but the previous user may have disabled them. My question is, how to get the main menu and default GUI back? I have attached a screenshot for reference. Thanks, Ankanish.
    • 1shan
      Could you open workbench and go to tools>options>Mechanical APDL and click restore defaults.
      Regards Ishan.
    • Ankanish
      Thanks for your kind reply. I tried what you suggested, but I am afraid it is not working. I also tried logging into the same system with other account, and checking the GUI. But still I am having the same problem. Is there any other solution.
      Thanks, Anish.
    • Ashish Khemka
      Try the following:
      Go to Menu Toolbar : PlotCtrls>Windows Controls> Reset Windows Options
      Please see if this helps.
      Regards Ashish Khemka
    • Ankanish
      Thanks for your kind reply. Sadly, this solution also does not work.
      Regards Anish
    • Ashish Khemka
      This looks like an installation issue. I will move this post to the installation.
    • Ankanish
      Thanks for your help. Much appreciated!
      Regards Anish Kulkarni
    • Yassine el qamch
      Please did you figured out the source of the issue?
Viewing 7 reply threads
  • The topic ‘Mechanical APDL GUI not showing Main Menu’ is closed to new replies.
