July 18, 2024 at 2:26 pm
Martin Ortega
SubscriberHi Community!ÂÂI'm using Ansys Workbench Student 2024 R1 on my Laptop with Windows 10 Home, Intell i7 7gen processos and Nvidia GTX1650 Mobile with standard configurations. ÂÂThe context :I need to code some small APDL code in Ansys Workbench Mechanical module by adding an APDL script to my analysis to fix the position of a section of a part after a deformation.ÂÂThe problem : When I apply a new APDL Script in mechanical, the command window to write my script does not show up and I can not write, copy or do anything in the command window. I only see a blank page and sometimes, just the 3D model in the back (See Figure 1). Materials properties in the mechanical tree does not show up either. (see figure 2 and figure 3). My Windows machine is regularly and automatically updated.ÂNote that I didn't have this issue when I first installed Ansys 2024 R1 on my laptop a few months ago. The problem appeared a few days ago. I tried to find a solution on the Ansys forums, YouTube and even reinstalled Ansys, but nothing works. ÂÂI am currently unable to find a solution to this problems, thus why I'm writing to today.ÂÂThank you in advance for your answer and have a good day! -
July 22, 2024 at 10:03 am
Sampat Kumar
Ansys EmployeeHi
Can you try to enter the below environment variable and let me know if this works or not?Â
Environment Variable :
variable name- "ANSYS_MECHANICAL_USE_WEBKIT" and value= "1"Best Regards,
Sampat -
July 22, 2024 at 11:42 pm
Martin Ortega
SubscriberHello Mister Kumar!
I just try your procedure and it work for both problems!
Thanks you so much for your help! I really struggled to find a solution and nothing help more than your solution!
I will make a follow up in the next days if I incure a new problem, but for now on, it work!Â
Thanks again!🥳🤙💯
- The topic ‘Mechanical, APDL and Materials Command Windows problem not functional’ is closed to new replies.
