April 10, 2024 at 5:07 pm
abatrach
SubscriberI am trying to do a frequency sweep simulation for a long, rectangular 3D, strip of metal. I am looking to extract the measured inductance and Q factor (losses) across the metal strip.
I want to use two terminals for this and make it so that these terminals/ports/references do not add inductance. I have attached a picture of my layer stack.Â1. I have tried to make terminals out of the two smallest, opposite faces of the yellow inductor by selecting the two faces, making each of them an object from the face, making each of the objects a terminal lumped port, and then assigning each of the lumped ports a terminal. I also made the top face of the pink material a pec ground reference. However, that did not work and the error said that there were too few conductors found on the port(s).Â2. I also tried to make a ground reference loop. I've attached a top-down view of the layers. The green square frame/loop is the ground reference conductor (a pec). I then drew two rectangles connecting the top edges of the inductor ends to the green frame. I made these two rectangles into ports, and making them lumped terminal ports automatically assigned terminals to them. This works and simulates, but I notice that the green frame adds extra inductance.ÂWhat is the way to simulate this without any added inductance in driven terminal mode?ÂThanks in advance! -
April 11, 2024 at 12:27 pm
Praneeth
Ansys EmployeeHi Lexi Batrachenko,
Thank you for reaching out to the Ansys learning forum.
Please add the image screenshots using the 'insert image" option as Ansys personnel cannot access the attachments in the forum due to export compliance.Â
Best regards,
Praneeth.-
April 11, 2024 at 4:14 pm
abatrach
SubscriberI have inserted the images, thanks.
April 15, 2024 at 1:55 pm
GioF
Ansys EmployeeHi Lexi,
Inevitably, any current flowing structure will contribute to the inductance calculation. HFSS calculated the closed loop inductance of the created structure.
A deembeding option is offered for terminal lumped ports, which removes the parasitic inductance that the ports are adding to your model. You can select each port and enable Deembed on the Properties window. You can find more information on numerically deembeding port inductance in HFSS.pdf help document - page 4404.
- The topic ‘Measuring Inductance Using two Terminals – driven terminal solution’ is closed to new replies.
5794
