March 17, 2021 at 2:57 pm
arshiah
SubscriberI received an error when I was coupling Maxwell and Simplorer. Any hints of suggestions to solve this issue would be greatly appreciatednnMaxwell2d solver, process solver2d error: Internal Solver Error: 'Edge is not preserved in the mesh!'. Please contact ANSYS technical support.n -
March 19, 2021 at 6:11 am
NKC
Forum ModeratorHi @arshiah,nCan you decouple Maxwell from simplorer and run Maxwell alone and see if the issue persists with Maxwell alone?nIf the error still persists with Maxwell, then it could be due to a mesh problem. Perform below one after the other. n1) Try to simplify if there are any complex geometries in your model and analyze.n2) Change the mesh method to classic and move the slider a bit towards a fine setting in initial mesh settings.n
3)Refer to Model Analysis section in the Maxwell help section for more details on model analysis for the mesh.n
nRegards,nNavyan
- The topic ‘Maxwell Simplorer coupling issue’ is closed to new replies.
1885
1403
1298
