March 6, 2026 at 7:49 am
saivishnu
Subscribercurrently using Thin layer for contact resistance , but from last 2024 R2 version if i add thin layer i am geeting 3Deqs error, is there any other way to add contact resistaceÂ
March 9, 2026 at 6:07 pm
MirandaH
Ansys EmployeeIf you get an error message: [error] Process '3deqs' terminated abnormally. It may have run out of memory or could have been killed by the user.
There is an error in the analysis settings or there is insufficient memory for the calculation.
If the error occurs immediately after the calculation, please check that the voltage and current settings and boundary conditions are correctly defined.
If the error occurs after a while after the calculation, please check the memory usage status in the Maxwell 3D menu > Results > Solution Data > Profile tab
5639
1885
1403
1298
