Electronics
Electronics
Maxwell 3D Animation
    • Mirucar
      Is it possible to make a 3D animation of an object in Maxwell? I want to analyze how some parameters change when my object is doing a rotational movement. How can I do this setup?
      Thanks
    • Navya Chode
      Hi @Mirucar
      Yes, you can visualize the rotational setup for each anlysis step by creating animation.
      Please refer to the below getting started example to understand how to do that.
      Regards Navya
    • Mirucar
      Thanks for your help Navya.
      Rather than a field, I want to analyze the torque values on a spindle which is doing a rotational movement. So at that moment, field overlays are not important for my situation. To be more descriptive, can I use the torque outputs instead of field overlays?
    • DELI
      the animation is more for field overlay, torque result could be plot in field report which is a XY plot.
  • The topic ‘Maxwell 3D Animation’ is closed to new replies.
