April 1, 2026 at 5:05 pm
q.qin
SubscriberHi,Â
I am setting up a 2D 2-way coupling simulation between Maxwell and static thermal simulation in Workbench using 2025R1 version.Â
I can get 1 way coupling results (Maxwell to Steady-State Thermal). But I cannot get temperature feedback to my Maxwell even with the help of the Feedback Iterator.Â
I have added thermal modifer and enabled temperature feedback in Maxwell.Â
However, I cannot find 'export after solve' or 'Export' in my Steady-State Thermal for 'Import Load'
I am following this setup:Â https://ansyshelp.ansys.com/public/Views/Secured/Electronics/v242/en/Subsystems/Maxwell/Content/CouplingMaxwellDesignswithANSYSThermalviaWorkbench.htm
According to the user manual for the above link, the 2-way coupling between Maxwell and Steady-State Thermal should work.Â
But I also found https://ansyshelp.ansys.com/public/account/secured?returnurl=/Views/Secured/corp/v242/en/wb_sim/emag_temp_results_export.html?utm_source=chatgpt.com
It shows exporting these results does not supported by 2D mechanical analysis. So I am very confused.Â
Would someone please let me know:Â
- Is it feasible for 2D 2-way coupling between Maxwell and Steady-State Thermal?Â
- If not, would it be possible to manually input/link the thermal distribution in Maxwell?Â
- If yes, are there any hidden bottom or processes that need to be taken, and have I possibly missed?
Thank youÂ
April 6, 2026 at 3:01 pm
MirandaH
Ansys Employee1‑way coupling (Maxwell → Steady-State Thermal) works for 2D, however, true 2‑way coupling (temperature feedback → Maxwell) is NOT supported for 2D in Workbench3D Maxwell ↔ Steady-State Thermal is supported and manual temperature feedback in 2D Maxwell is possible, but it is not automatic nor iterative via Feedback Iterator will need scripting.
6855
1343
1152
