March 6, 2019 at 11:02 pm
Sam Fares
SubscriberHello,
Is there a way to have Ansys calculate the load required to yield a material in a component?
Thanks,
Sam
March 7, 2019 at 12:14 am
peteroznewman
SubscriberHello Sam,
Use a linear elastic material: just Young's Modulus and Poisson's Ratio.
Apply a unit load, F = 1 lbf and solve.
Insert the Equivalent vonMises Stress result and obtain the maximum Stress, Sm.
The load Fy required to reach the Yield Stress, Sy isÂ
Fy = Sy/Sm.
Since everything is linear, the ratio of forces is equal to the ratio of stress.
That assumes you have done a Mesh Refinement Study and have converged on the exact maximum stress.
Regards, Peter
March 7, 2019 at 3:32 am
sathya
SubscriberHi If you consider nonlinearities in your setup,you have to run for higher load with enough substeps to predict failure.no shortcut. -
March 7, 2019 at 3:57 pm
Sam Fares
SubscriberThank you Peter!
Sam Fares
SubscriberThank you Sathya
Viewing 4 reply threads
- The topic ‘Maximum Load to yield a material in a component’ is closed to new replies.
