December 8, 2021 at 8:32 am
BurtonKim
SubscriberHi
I don't know which I have to see..
Max Principal Stress / Max Principal Strain / Von-mises StrainÂ
I'm trying a drop simulation and find the strain of the packaging of the product.
Please Help me.
Thanks very much. Regards
December 8, 2021 at 9:20 amVinayak Vipradas
These are different measures of Strain based on different theories and each one of them is used for a different purpose. In general, the selection of the Strain Measure depends on the nature of the material (ductile/brittle), and the expected mode of deformation(tension/ compression). For drop test simulation, if you want to find the permanent strain in the body, you can use Equivalent Plastic Strain.
For detailed information on different measures of Stress and Strain, please refer to the following links:
Stress and Strain (ansys.com)
Regards Vinayak
December 9, 2021 at 11:27 amBurtonKim
SubscriberThank you very much !!! A lot of help.
Viewing 2 reply threads- The topic ‘Max Principal Stress vs Max Principal Strain vs Von-mises Strain’ is closed to new replies.
6750
1324
1087
