June 26, 2019 at 3:52 pm
jiahao
SubscriberI am using the explicit dynamics to model the large deformation of a surface model. The material is based on Mooney-Rivlin 5 Parameters model, as shown bellow:
When I start the solving process, it just stops immediately with problem "Material with invalid equation of state assigned to Part 1.". However, when i use static mechanical to solve the problem, there is no problem. I am wondering whether this model is applicable for surface body in explicit dynamics? Thanks,
June 26, 2019 at 5:22 pm
jj77
SubscriberÂ
The user manual (explicit dynamics) says that Hyperelastic material only work with 3D parts not with surface bodies.
- The topic ‘Material with invalid equation of state assigned to Part 1.’ is closed to new replies.
