June 15, 2023 at 6:11 pm
Atefeh Sadrimofakham
SubscriberHello eveyone. I am working on wafer simulation in CMP process. Do you know how we can see/gain the results for material removal rate (MRR)? -
August 7, 2023 at 8:25 am
Praneeth
Ansys EmployeeHi,
Thank you for reaching out to the Ansys learning forum. We appreciate your patience.
Unfortunately, we could not reply to you earlier as we did not notice your post until now.
Please let us know the Ansys tool that you are using to help us serve you better.
Best regards,
Praneeth. -
August 14, 2023 at 9:18 pm
SubscriberIn Chemical Mechanical Polishing process, we polish a Silicon Oxide/Nitride wafer on the Polyurthane pad. The ununiformity on the wafer surface will be decreased and flattened based on this process. So, I wonder if is there any possibilty to calculate the amount of the Material Removal Rate from the wafer surface? (It is something like erosion.) https://en.wikipedia.org/wiki/Chemical-mechanical_polishing. Here is more information about the CMP process.
August 15, 2023 at 7:50 am
Praneeth
Ansys EmployeeHi Atefeh,
Please provide the Ansys tool name that you wish to use to help us serve you better.
Best regards,
Praneeth. -
August 15, 2023 at 5:24 pm
SubscriberAnsys Fluent
August 17, 2023 at 8:58 am
Essence
Ansys EmployeeHello,
Did you try using the Ansys Rocky which can be coupled with Ansys Fluent for your application?
- The topic ‘Material Removal Rate’ is closed to new replies.
