July 11, 2024 at 8:24 am
Bjarne Warnecke
SubscriberI have the following problem: I have created a geometry with very fine meshing in pyMAPDL. If I now want to import the cdb. file into ANSYS Mechanical, either the material data is lost (is simply no longer displayed in ANSYS Mechanical) or the import fails completely.
If the meshing is less fine, everything works perfectly. I suspect that the problem is due to too many nodes. What can I do?
July 15, 2024 at 3:19 pm
mrife
Ansys EmployeeHi Bjarne
What material models are you using? The External Model component in Workbench does not support every material model that MAPDL can define. Check the Workbench help on the External Model system for more information (if you have access).
Do you link the External Data to the Engineering Data of the Analysis System too?
Mike
- The topic ‘Material properties get lost while importing .cdb file’ is closed to new replies.
