June 15, 2023 at 11:29 am
deepak
SubscriberHello,
I'm working on a simulation of an axial flow turbine with the following parameters;
Inlet mass flow rate = 1.5 kg/s = 5400 kg/hr
Inlet temp (i.e. steam temp.) = 250 deg C
Outlet pressure = 0.18 bar(A)
Solver = ANSYS CFXI would like to know how can I accurately define the material (i.e steam)?
Should I be using "water vapor" material available in the databse or is there an alternate method to do the same.
Any help will be highly appreciated as Im working on my research project. -
June 16, 2023 at 4:54 pm
V.P
Ansys EmployeeHi Tocol,
Steam as a material is available in the CFX material list under the IAPWS library. More on setting up Steam can be referred to from the CFX User guide. I am sharing a link to one chapter in the user guide which specifically deals with setting up Steam as a material. Chapter 29: Steam Jet (ansys.com)
Hope this will help you get started.
- The topic ‘“Material” for Superheated Steam.’ is closed to new replies.
5729
