July 17, 2024 at 12:09 pm
surmalumyan
SubscriberHi!I want to analyse CNT(Carbon nanotubes) cement matrix in Ansys, by using MD,Since the CNT diameter is almost 15nm, the meshing process starts to be inaccurate.There is the space for the maximum size for elements, whatever I write in these space CNT's triangulation size is not changing (keeping small sizes), making difficulties in the next parts of MD.How to increase the triangulation size of CNT?Regards, Suren MalumyanThank you a lot. -
July 18, 2024 at 12:00 pm
Federico
Ansys EmployeeHello Suren,
I assume you are using SpaceClaim meshing? what are the units of your document? You can check this in File > SpaceClaim Options > Units... and set the length to something smaller to increase the precision.
July 19, 2024 at 12:39 pm
surmalumyan
SubscriberThanks for the reply.
Yes, I used SpaceClaim to create the mesh, since MD is in the SpaceClaim.
The units chosen are nanometers,
The aspect ratio for MWCNT is 500-1000. (ex., diameter is 20 nm, length 20*500 nm),
How can I reduce the quantity of meshing triangulation, if I already have put the maximum value for the element size.?
July 19, 2024 at 12:44 pm
surmalumyan
SubscriberIn other words, after some maximum size, the meshing triangulacion elements quantity is not changing (not decrease). -
July 24, 2024 at 10:47 am
surmalumyan
Subscriber????
September 20, 2024 at 1:30 pm
surmalumyan
SubscriberPlease can you answer how can I model nanoparticles with accurate meshing?
Viewing 5 reply threads
- The topic ‘Material Designer: Meshing difficulties’ is closed to new replies.
1885
1404
1303
