Materials
Materials
Topics related to Granta Design and more.
Material Data as a Function of Independent Field Variables
    • matteo.cova
      Hi. I am modeling powder compaction using the Extended Drucker Prager\Cap material model. The material of interest exhibits a so called "elastoplastic coupling", meaning the elastic properties (young modulus and poisson's ratio) are not fixed but dependent on density, which varies during compaction itself. One can think of it as an elastic hardening. This behavior can be addressed in Abaqus, since it gives you the power to define material properties as a function of other variables: for example, as to define a work-hardening curve, stress can be given as a function of equivalent plastic strain. Is there a way to do that in Ansys as well? from the documentation i could only find the tbfield command but it seems it can only describe properties as function of time or position in space.
      Thank you for your time
    • ashish.khemka
      It looks that this query is already answered here: Material Data as a Function of Independent Field Variables
      I will close the topic.
      Ashish Khemka
  • The topic ‘Material Data as a Function of Independent Field Variables’ is closed to new replies.
