January 31, 2024 at 12:12 pm
Prajyot c
SubscriberHello,
I am a student at BITS Pilani and I am working on a project related to the shrink wrap process. I want to simulate the mechanical behavior of heat shrinkable film using LS-DYNA, but I am not sure how to characterize the material properties of the film. I have read some papers on the topic, but they use different material models such as Thermoviscoelastic Model.
Can anyone suggest a suitable material model and calibration method for heat shrinkable film in LS-DYNA? I am looking for a model that can capture the nonlinear, viscoelastic, and anisotropic behavior of the film under thermal loading.Do I need some experimental data on the film, such as stress-strain curves, relaxation tests, and shrinkage tests?
Any help or guidance would be greatly appreciated. Thank you in advance.
February 1, 2024 at 7:47 pm
Ushnish Basu
Ansys EmployeeYou can try the material selector here as a guide: https://lsdyna.ansys.com/dynamat/
February 19, 2024 at 8:56 am
Prajyot c
SubscriberThanks for reply...I have tried using it not much helpful.
- The topic ‘Material Characterization of Heat Shrinkable Film in LS-DYNA’ is closed to new replies.
- Press hardening characterization
- Temperature-dependent viscosity model used in FLUENT flow analysis
- Explicit Dynamics Material properties
- Get ultimate strength value from simulation
- Softening Issues in Reinforced Concrete
- Error on Material Designer, One or more errors occurred.
- Material Designer, Different warp and weft shares in woven RVE
- Material Designer – Material Assignment
- orthotropic material proprierties give me “missing” data, what could it be?
- Shape Memory Alloy Deployment
1937
839
599
591
366
