Ansys Products
Ansys Products
Material Assignment Not Working in ANSYS Explicit Dynamics
    • s4415222
      I am currently using ANSYS Mechanical 2025 R2 as part of my university work, and I am experiencing a persistent user interface issue.
      When attempting to assign materials to geometry bodies, the material selection panel appears as a blank white box instead of displaying the available materials. This prevents normal interaction with the material selection interface.
      I have already attempted the following troubleshooting steps:
      • Resetting the UI layout
      • Deleting the ANSYS AppData configuration folder (v252)
      • Forcing software rendering using environment variables
      • Changing Windows graphics settings to use integrated graphics
      • Restarting the application and system multiple times
      Despite these steps, the issue persists.
      This appears to be a rendering/UI bug specific to this version. I have attached screenshots demonstrating the issue.
      Could you please advise on:
      1. Any known fixes or patches for this issue
      2. Whether this is a known bug in ANSYS 2025 R2
      3. Recommended workaround or configuration changes
      System details:
      • ANSYS Version: 2025 R2
      • OS: Windows 11
      • GPU: RTX 5050
      This issue is currently affecting my ability to efficiently complete a Formula Student impact attenuator simulation.
      Thank you for your support.
    • ErKo
      This is a common problem unfortunately (at least what you show in the image).
      In wb mechanical go to File>Options>UI Options>Engineering Data>Mechanical View = None
      All the best
      Erko
