March 27, 2024 at 5:01 am
yjg298
SubscriberI want to proceed with the analysis of the ball hitting the glass and breaking it. The photo below shows the plate made of aluminum using 18.MAT_POWER_LAW_PLASTICITY. I want to change the aluminum material to glass material. I want to use 280.MAT_GLASS. Can you give me an example? What I am using is the free version, LS-PrePost.
March 27, 2024 at 1:33 pm
Ram Gopisetti
Ansys EmployeeHi Yoon,Â
Please refer to comments given by my colleague in the followign linkÂ
/forum/forums/topic/windshield-glass-roof-material-modeling/
Cheers, RamÂ
March 28, 2024 at 2:30 am
yjg298
SubscriberThank you for your answer! However, the example in the link you provided cannot be run on my computer. If you don't mind, I'll show you an example I made so you can tell me what's wrong. Looking forward to hearing from you!
March 31, 2024 at 5:15 pm
Tonmoy
SubscriberHi Yoon,
The example file is in *.tgz extension, or in gunzip format. Please use winrar or similar software to extract the input deck residing inside it. If you're using terminal use can use the command
tar -xvzf /path/to/yaris_windshield_mat_280_pse.tgzto extract those.Â
Thanks,
Tonmoy.
March 28, 2024 at 4:20 pm
April 2, 2024 at 2:20 am
yjg298
SubscriberHi Dale,
This is an example I created. The model disappears after 2.18seconds. Please tell me what's wrong.
https://drive.google.com/file/d/1OMTiGYcBIPhgGc_9w50GFTNuNWNTy8yW/view?usp=drive_link
April 3, 2024 at 5:24 pm
Tonmoy
SubscriberHi Yoon!
Check out this tutorial in Youtube: https://youtu.be/MWqyCnA6B9c and this example from LSTC: https://www.dynaexamples.com/introduction/intro-by-a.-tabiei/contact/contact-eroding-i
You can also check out the example that was provided by the ANSYS employee above.
Thanks, Tonmoy.
- The topic ‘MAT_GLASS’ is closed to new replies.
5804
