TAGGED: ale, axisymmetric, energy-conservation, ls-dyna, sale
August 3, 2026 at 11:48 am
sqslh
SubscriberHello,
I am investigating an output-mapping and energy-conservation issue in an academic civil/mining solver-verification unit test. This is not a weapon or defence model.
Environment:
Ansys LS-DYNA Student, Windows x64
SMP double precision R16.1-180-gd50332dbe5, one thread
Units: mm-ms-g-N-MPa
2D axisymmetric S-ALE, 12,423 cells
808 cells initially filled with EMULSION
*MAT_HIGH_EXPLOSIVE_BURN (MAT_008, BETA=0) with *EOS_JWL
NEIPH=4, D3SALE=0, DMPMSH=1
Termination time: 0.100 ms
I compared two input decks that are identical except for the lighting time LT in *INITIAL_DETONATION:
v3: LT=0.0 ms
Normal termination, but the maximum absolute total-energy drift calculated from all original GLSTAT states is 15.995852%. -
E2: LT=0.200 ms, after the 0.100 ms termination time
Normal termination, and the maximum absolute total-energy drift is only 0.00049064%.
No interpolation, state deletion, filling, smoothing or renormalization was used.
However, I cannot yet prove from the original output that burn fraction F remained zero in all 808 explosive cells in E2. The binout contains only nine tracers, and the R16.1 manuals do not identify the exact full-field burn-fraction mapping for 2D axisymmetric S-ALE.
Could an LS-DYNA specialist please clarify:
With D3SALE=0, where exactly is the per-S-ALE-cell MAT_008/JWL burn fraction F stored in d3plot? Please identify the documented array/record location and the LS-PrePost Fcomp or Misc component.
With D3SALE=1, what is the corresponding LSDA path and array name in d3sale?
Is NEIPH=4 sufficient for full-field burn-fraction output for MAT_008 + EOS_JWL in 2D axisymmetric S-ALE? Does HISNOUT=3 provide valid labels for this field?
Are these output fields identical between the R16.1 Student and commercial executables?
Is the approximately 16% energy loss for LT=0, compared with approximately 0.00049% for LT=0.200 ms, a known R16.1 limitation, defect or energy-accounting behavior? Is there a recommended patch level, diagnostic output or control setting?
I am not claiming that the A/B comparison uniquely proves that burn, JWL or advection is the cause. I first need the officially supported full-field burn-fraction mapping.
August 3, 2026 at 12:21 pm
erik.kostson
Ansys EmployeeHi
Ansys empl. can not provide feedback on this. Wait for other users to chime in.
All the best
Erko
August 5, 2026 at 7:06 am
sqslh
SubscriberThank you for clarifying, Erko. I understand and will wait to see whether other LS-DYNA users can share their experience.
All the best
