LS Dyna
LS Dyna
MAT275 Smooth Viscoelastic Viscoplastic material
    • parth.shingte
      Hi all,
      I am trying to simulate a forming process for PET material. I am trying to use the MAT275 material model on LS DYNA V4.10.8. When I try to simulate the process, the part with MAT275 disappears from the simulation and the simulation immediately shows normal termination. I see no error messages in the .out or messag file. If i use another material model (say MAT124) then the simulation runs correctly. I am using ELFORM 15 shell elements. (Axisymmetric Solid)
      What could be the reason for this? Is it due to bad material parameter definition or is there another issue?
    • Nanda
      Your suspicion is correct. It could be something related to a bad material parameter or a complete mismatch between material parameter units and input deck units. I would narrow it down by checking for units and adjusting the parameters here and there to see if it resolves the issue.
      Nanda.
      Introducing Ansys Assistant a 24/7 AI-powered virtual assistant for active Ansys academic customers.
      Have a look at our public help documentation website: Ansys Help
      For more exciting courses and certifications, hit this link: Ansys Innovation Courses | ANSYS Innovation Space
