April 28, 2026 at 11:11 am
engelmann
SubscriberDifferent moment in the node from a frame corner - the node is the end node of the first element and is equal to the start node of the second element. It is caused by ENRELEASE because it creates during SOLVE two nodes at the same location. As a result, two different moments arise in the same place. However, this is only the case when using ASEC cross-sections.
Viewing 0 reply threads
