July 18, 2024 at 2:03 pm
sbrusca
SubscriberHello to everyone,Â
The question is relative to management of participation factor.Â
Is it possible to use a Command APDL for avoiding to exctract frequency with a low value of PF? I remember that I did it in Mechanical but I don't remember the snippet.Â
Can you help me?Â
Thank youÂ
July 18, 2024 at 4:35 pm
Ankush Choudhary
Ansys EmployeeHi,
You can use the MXPAND and MODSELOPTION commands for that. Please check out the below link on this approach.
July 19, 2024 at 9:21 am
ErKo
Ansys EmployeeÂ
Hi
There is also a native setting in wb mechanical and a harmonic response system (MSUP – so modal MSUP harmonic response). It is under analysis settings and is called:
Mode Selection Method – set that to Modal Effective Mass and then set a threshold for the Ratio of Effective Mass to Total Mass (so if set to say 0.2 it will take modes with a Ratio of Effective Mass to Total Mass higher than 0.2).
See here for more info on the above:
Coupled Field Harmonic, Harmonic Acoustics, and Harmonic Response Options (ansys.com)See here how to aview the above help link:
https://innovationspace.ansys.com/forum/forums/topic/how-to-access-the-ansys-online-help/Â
July 29, 2024 at 2:34 pm
sbrusca
SubscriberHello to everyone and thank you for your responses.Â
I can apply the second method (with a filter in Harmonic Response Options).Â
I can not appy the first method because I have this error:Â
MXPAND,20,,,NO,0.2,YES,MODM,,
modseloption,no,yes,no,no, no,no,ÂWith this commands I think that must extract only modes with a PF>0.2 in Y direction.Â
And I can not see the participation factors and the simulation does not extract the right frequencies.Â
Can you help me?Â
Thank youÂ
July 29, 2024 at 2:43 pm
sbrusca
SubscriberMaybe I found the reason:Â
! Obtain the Modal Solution
/solu
antype, MODAL
modopt, LANB,12 ! Block Lanczos
solve
finish! Perform the modal selection and expansion
/solu
antype, MODAL, RESTART
mxpand,,,,yes,0.1,, MODM ! Mode selection is based on the modal effective mass, and element
! results are requested
modseloption,no, no,yes, no,no,no ! Only direction X is selected, a minimum of 90% of the total
! mass is requested in this direction
solve
finishI need to perfom a pre-modal simulation and after I can apply my filters.Â
Is it the only solution right?Â
Thank youÂ
- The topic ‘Management of Participation Factor’ is closed to new replies.
6765
1330
1102
