3D Design
3D Design
Make a shell with a changing thickness
    • Babeth
      Hello !
      Is it possible to make a shell with a changing thickness in SpaceClaim ?
      Like a linear fonction depending on the z-axis coordinates ?
      Elisabeth
    • Govindan Nagappan
      You will have to define the thickness as a function in Mechanical. It is not defined in Spaceclaim
      See help section: Specifying Surface Body Thickness (ansys.com)
  • The topic ‘Make a shell with a changing thickness’ is closed to new replies.
