September 23, 2024 at 1:19 pm
September 25, 2024 at 11:04 am
V.P
Ansys EmployeeHi,Â
Solution:
Try adjusting the DPI settings specifically for CFD-Post:
Right-click on the CFD-Post application or its shortcut.
Go to Properties → Compatibility tab. In the settings section, you will find 'Change high DPI settings'.
Check the option 'Override high DPI scaling behavior' and set it to 'Application'.
Apply the changes and restart the application. -
September 26, 2024 at 3:07 pm
scabo
SubscriberHi, thanks but i am opening CFDPost directly from command terminal of my HPC. So there is no Properties tab or i cannot right click on it as such. It opens by command..
