Electronics
Electronics
Magnetic field distribution – Help to see the field across all options
    • Sean Langdale
      As can be seen in the snip below, I'm trying to model a steel wall and ceiling room with a coil running through it and understand the magnetic field distribution into the room by placing a non modelled part.  I'm looking to see the full field distribution in the steel, in the room and outside the room (on the non modelled square.  Currently I only be able to choose one option when I go into the magnetic field - modify plot.  The option to choose "All Objects" does not work and will not show me the the field across all the objects listed.  Does anyone have any ideas?
    • GLUO
      Please select the all object in the view, then right click them>>Fields>>Mag_B and click OK. Do not change anything in "in Volume"
      GL
  • The topic ‘Magnetic field distribution – Help to see the field across all options’ is closed to new replies.
