April 2, 2024 at 3:22 pm
Tian Xiang Thong
SubscriberWith regards to this post, I would like to do the exact same thing to validate my simulation results. How can I do this in 2D?
It seems like I cannot apply current along the wire as the current excitation only applies out of or into the plane (z-direction) which produces circular magnetic field like this:
I can obtain somewhat expected using 3D like this. But the pattern is not so good I suspect is due to mesh.
I am quite new to this software and can't seem to find any tutorial on how to do this. Please help me thanks.
Thong -
April 5, 2024 at 5:38 pm
GLUO
Ansys EmployeeHi,
Are you trying to observe the flux density distribution due to the eddy current (like skin effect) on the current carrying object?
GL
April 6, 2024 at 5:05 pm
April 8, 2024 at 3:20 pm
GLUO
Ansys EmployeeSeems like a picture is missing here..The B field is affected by the current distribution inside the conductor. 2D desings only allow Z directional current, unless you would like to manually apply current at other directions, 2D is good enough to capture the AC effects.Â
GL
April 9, 2024 at 2:39 am
April 9, 2024 at 3:16 pm
GLUO
Ansys EmployeeThe picture is showing flux density instead of current, but yes, you can only assign current out of or into the page.
GL
April 9, 2024 at 4:03 pm
Tian Xiang Thong
SubscriberThank you for your clarification. Yes I am interested in the flux density instead of current.
- The topic ‘Magnetic Field Around A Current-Carrying Wire’ is closed to new replies.
6134
