December 2, 2021 at 5:47 pm
photoholicboy_cr2
SubscriberWhere can I find the thermal and structural proprieties from M19 Steel from the RMxprt library? I need to do an electrical, thermal and structural from an Axial Flux Motor, so I need those parameters. Can anyone give to me some information? Thanks
December 7, 2021 at 1:59 pmAshish Khemka
I am not sure about the electrical properties. But for thermal and structural properties please see if they are comparable to Structural Steel. By default, we have the properties for Structural Steel. Otherwise you will need to have the experimental data. Some of the papers have the data that may be helpful:
[PDF] Performance Analysis of High Grade M 19 Silicon Steel Core for Distribution Transformer | Semantic Scholar
(PDF) Investigation for Losses of M19 and Amorphous Core Materials Asynchronous Motor by Finite Elements Methods (researchgate.net)
Regards Ashish Khemka
Viewing 1 reply thread- The topic ‘M19 Steel from RMxprt Thermal and Structural Proprieties’ is closed to new replies.
5834
