April 20, 2021 at 9:37 pm
KCCHIEN
SubscriberHi Lumerical Support team,nI would like to simulate the intensity pattern under a colloidal nanosphere hexagonal array. For our experiment, we use a 325nm laser for the exposure of the photoresist, so I set the max and min wavelength of the light source is 325 nm. However, in the figure of spectrum vs wavelength, the range of the light source is from 292nm to 365nm. nTherefore, how can I solve this situation? Should l increase the pulselength? Or what is the standard procedure to set up a simulation for a single wavelength light source in Lumerical?nThanks in advance,nKC Chienn -
April 21, 2021 at 7:13 am
Shelley
SubscriberEven if you set the max and min wavelength of the light source are 325nm, the FDTD will also inject broadband source. You may set the monitor using single wavelength to achieve your demand.n -
April 23, 2021 at 7:57 pm
Chris Kopetski
Ansys EmployeeMore details can be found in this post:nWhy does FDTD inject a pulse when I want a steady state, single frequency CW sourcenn
- The topic ‘Lumerical simulation for a single wavelength’ is closed to new replies.
Ansys Innovation Space
1431
1272
1119
1015
