October 3, 2023 at 9:35 pm
October 5, 2023 at 5:29 pmLitoAnsys Employee
There seems to be an issue with your local computer connecting the license manager on your server. This could be a network connectivity issue where your local computer is losing the connection between the license server. This typically happens when your computer is on a different network or you are connecting via the Internet.
Please check with your IT to fix the network connectivity issue between your computer and the license server.Â
- The topic ‘Lumerical – Ansys License server error’ is closed to new replies.
Ansys Innovation Space
- Difference between answers in version 2024 and 2017 lumerical mode solution
- Errors Running Ring Modulator Example on Cluster
- INTERCONNECT – No results unless rerun simulation until it gives any
- Import material .txt file with script
- Help for qINTERCONNECT
- Trapezoidal ring
- Issues with getting result from interconnent analysis script
- How to measure transmission coefficients on a given plane .
- Topology Optimization Error
- Absorption cross-section of AuNR excited by prism-based TIR
591
544
524
366
