July 18, 2023 at 10:46 am
July 19, 2023 at 1:42 pm
Ram Gopisetti
Ansys EmployeeHi, if you use the case means you are exploring the solution as the variable combination of different parameters,Â
why d you want to combine the results, what do you want to achive from it !
cheers, RamÂ
- The topic ‘Ls-PrePost Post-processing problem’ is closed to new replies.
1885
1403
1303
