September 8, 2023 at 5:53 am
Yuju Chen
SubscriberI used Python to trigger LS-PrePost to execute a .cfile in batch mode. Everything works well on my laptop.However, when I execute my Python code on the server, LS-PrePost crashes without any apparent reason. Has anyone had a similar experience?
September 8, 2023 at 2:55 pm
igandiko
Ansys EmployeeDid you try running LSPP in batch mode on the server first, without using python? What command are you running? There are couple of options, as shown below. If the first command does not work, try the second. I also suggest using the latest LSPP version.Â
/path/lspp410 runc=cfile
/path/lspp410 -nographics c=cfile
- The topic ‘LS-PrePost batch mode happened APP crashed in server environment’ is closed to new replies.
Ansys Innovation Space
1243
1092
1068
953
