May 1, 2024 at 6:20 pm
amdifut
SubscriberGood Afternoon,
I am currently working in LS-PrePost and I am trying to create a pulsatile, sinusoidal inlet velocity for a 2D geometry simulation. The inlet velocity expression is 0.0266*0.00786*sin(2*3.14*0.3*TIME). For the inlet velocity, I have inserted via the keyword *DEFINE_CURVE_FUNCTION as shown in the image, however I am receiving an error.
What are the steps to correcly apply this pulsatile sinusoidal function to the inlet?
May 3, 2024 at 2:46 am
Reno Genest
Ansys EmployeeHello Andy,
What you are doing seems correct to apply a pulsating inlet velocity with the ICFD solver in LS-DYNA. You are using the *ICFD_BOUNDARY_PRESCRIBED_VEL keyword and specifying the pulsating inlet velocity using a load curve with *DEFINE_CURVE_FUNCTION. Also, *ICFD_BOUNDARY_PRESCRIBED_VEL is applied to part 1 which is the inlet.
The warning message is about the *ICFD_MAT ID=1 card. Could you post a screenshot of *ICFD_MATÂ ID=1 in your model? Are load curves ID 1701669236 and 41 refered to in *ICFD_MAT ID=1? Do you have these load curves defined in your model with the *DEFINE_CURVE keyword?
Also, what happens if you run this model with the LS-DYNA solver? Do you get an error message? If so, what is it?
Reno.
May 3, 2024 at 12:52 pm
amdifut
SubscriberHi Reno,
I ended up resloving the issue by using LS-Prepost on another server. I am not sure what excatly was causing the issue, but I replicated my steps in another server and it worked without getting any errors. However, I was missing a Point ID for selecting angular velocity within the ICFD_BOUNDRY_PRESCRIBED_VEL.Â
To answer your question, before creating the POINT ID, When I ran the model in LS-RUN, it would run for a about 15 seconds then it would terminate. Once I looked into the message file, I notice the termnination was caused by a missing POINT ID. I have attatched my ICFD_MAT ID for your reference.Â
Thank you for replying back to me.Â
May 3, 2024 at 6:12 pm
Reno Genest
Maybe the version of LS-PrePost you are using on the different computers are different.
It seems you are all set for now. If you don't have further questions, I will close this topic.
Have a great day!
Reno.
- The topic ‘LS PrePost – Pulsatile Inlet Velocity Keyword error’ is closed to new replies.
6189
