April 26, 2025 at 6:42 am
1642158661
SubscriberError 20368 (STR+368)mat/set id used in prescribed b.c.must be defined as rigid see card no.= 1 mat= 7in the velocity b.c. input section*** Error 20368 (STR+368)mat/set id used in prescribed b.c.must be defined as rigid see card no.= 2 mat= 7in the velocity b.c. input sectionLS-PerPost怎么解决错误 -
April 28, 2025 at 3:25 pm
igandiko
Ansys EmployeePlease check the nodes/parts defind in *BOUNDARY_PRESCRIBED_<> cards. Maybe you're using the card that is meant for rigid parts but the material of the part is not defined as rigid.
Ansys Innovation Space
971
857
783
772
