LS Dyna
LS Dyna
LS-DYNA Network Task Control Inconsistency error
    • robgics
      We recently upgraded from Ansys 2019R3 to 2021R1, and some users have experienced problems using LS-DYNA.
      I was able to duplicate the error using an example from https://www.dynaexamples.com/introduction/examples-manual/misc/airbag.
      [[email protected] stuff]$ lsdyna211 i=./airbag.deploy.k
       Executing /opt/aci/ansys/2021R1/v211/ansys/bin/linx64/lsdyna_sp.e
       License option : check ansys licenses only
         Date: 09/14/2021   Time: 11:50:21
         | LS-DYNA, A Program for Nonlinear Dynamic    |
         | Analysis of Structures in Three Dimensions   |
         | Date  : 10/15/2020  Time: 07:56:29     |
         | Version : smp s R11.2.0            |
         | Revision: R11.2-66-g4cdf4c9c50         |
         | Features enabled in this version:       |
         |  Shared Memory Parallel            |
         |  FFTW (multi-dimensional FFTW Library)    |
         |  Interactive Graphics             |
         |  ANSYS License (ANSYS211)           |
         |  MADYMO indirect coupling (7.2 or higher)   |
       *      ANSYS 2021 R1     LEGAL NOTICES       *
       > i=./airbag.deploy.k
       Input file: ./airbag.deploy.k
       The native file format    : 32-bit small endian
       Memory size from default   :  20000000
       on UNIX computers note the following change:
       ctrl-c interrupts ls-dyna and prompts for a sense switch.
       type the desired sense switch: sw1., sw2., etc. to continue
       the execution. ls-dyna will respond as explained in the users manual
        type           response
       ******** notice ******** notice ******** notice ********
       * This is the LS-DYNA Finite Element code.          *
       Beginning of keyword reader                  09/14/21 11:50:21
       Memory required to process keyword   :   521120
       ******** UNEXPECTED ERROR - NETWORK TASK CONTROL INCONSISTENCY *******
       *** Error 70022 (OTH+22)
         Please contact
          Livermore Software Technology, LLC
          Tel: 844.Go.Ansys (844.462.6797)
          Email: [email protected]
       E r r o r  t e r m i n a t i o n
      Please let me know how to fix tihs.
      Thanks
    • tslavik
      Hello It appears you are using a FlexLM license. Is that correct?
    • robgics
      Yes, correct.
      I have reviewed the license currently in use, and it has the LS-DYNA entries in it. It does not expire until this November.
      We recently moved the LM from a different host to the current one, and the license currently in use reflects this change.
      I do notice that when LSDYNA displays license and platform data (when I execute it), it says "Licensed To: ", but no one is listed. Here is the section of output relevant to that.
      Features enabled in this version:|
      |Shared Memory Parallel|
      |FFTW (multi-dimensional FFTW Library)|
      |Interactive Graphics|
      |ANSYS License (ANSYS211)|
      |MADYMO indirect coupling (7.2 or higher)|
      |Licensed to:|
      |Platform: Xeon64 System|
      |OS Level: CentOS release 6.10 uum|
      |Compiler: Intel Fortran Compiler 16.0 SSE2|
      |Hostname: comp-ic-0016.acii.production.int.a|
      |Precision: Single precision (I4R4)|
      In another thread, I saw where I should set LSTC_LICENSE and LSTC_LICENSE_SERVER env vars, and I tried that...but it still didn't work.
    • robgics
      We recently were running Ansys 2019R3 on our system as well as 2021R1 (2 different LMs). At that time, the user was using LS DYNA on 2019R3 and all was well. When our license expired for 2019R3 at the end of August, then the user started using LS-DYNA on 2021R1 and has had the problem since. So they've never gotten it to work on 2021R1.
    • TrentE
      The message printed on the terminal included this:
      That means that there are environment variables set that cause the program to check for ANSYS licensing. It may be that LSTC_LICENSE should be unset, but check with your ANSYS Account Manager about that.
    • robgics
      So here is the solution....use the correct license. Ansys support gave me some license-related utils to run, and looking at the output, I could see there was no LS DYNA (or "dyna") entitlement. In fact, I could see that all of the expiration dates were wrong. That led us to looking at the license file in use and discovering it was incorrect.
      I told Ansys support that it would have been more helpful in the LS DYNA error message had included the word "license" in it somewhere.
      Thank you all for the help.
Viewing 5 reply threads
  • The topic ‘LS-DYNA Network Task Control Inconsistency error’ is closed to new replies.
