March 27, 2024 at 5:56 am
zhwzhwei
SubscriberI applied rotational angle load using remote displacement in Workbench/LS-DYNA, and the moment reaction could not be extracted from the result? How to extract the torque reslut in LS-DYNA?
March 27, 2024 at 2:17 pm
Ram Gopisetti
Ansys EmployeeHi zhwzhwei,Â
Recently we have given the option to use the binout tracker where you can check the moment causing from the remode displamcnet or the CNRB, currently it only gives out the forces but not the moments, so you have use the LSPP to read in the binout file then use the bndout sub-branch to post process the moments in subjective direction.Â
Cheers, RamÂ
March 27, 2024 at 2:29 pm
zhwzhwei
SubscriberOK,thank you very much
- The topic ‘LS-DYNA moment reaction’ is closed to new replies.
