September 17, 2026 at 6:53 am
guillaume.renedo
SubscriberDear all,
I was wondering whether there is a way to define an isotropic power-law model using the *ICFD_POROUS_MODEL keyword, as is possible in Fluent, for example.
The current card only seems to offer the Ergun and Darcy–Forchheimer models.
I would appreciate any guidance you could provide on this.
Thank you in advance for your help.
Best regards,
Gred
September 17, 2026 at 11:42 am
erko
SubscriberHi Gred
As you correct say, I do not think this is possible.
All the best -
September 17, 2026 at 12:58 pm
guillaume.renedo
SubscriberHi Erko,
Thank you for your reply.
I was looking for a way to implement a power law behavior through a power-law viscosity model coupled with Darcy's law.
Do you know how the velocity v in Darcy's law is computed when the Forchheimer coefficient is set to zero?
Is it the volumetric average velocity over the entire porous-media volume? Or the area-average velocity at the porous media's inlet ?
Best regards.
September 17, 2026 at 1:43 pm
erko
SubscriberHi
I am not a developer in ICFD so would not know.
Perhaps talk to the channel partner/ADDL that supports you , and they can open up a so called TRR (or perhaps a support ticket) request so my colleagues can try and see if there is a way to do what you want.
All the best -
September 18, 2026 at 8:22 am
erko
SubscriberHi Gred
I have spoken to R&D on your behalf and they will look into implementing the power law in the future version.I will convey this to the channel partner also.
All the best
