September 23, 2025 at 1:38 pm
elif.cayiroz
SubscriberHi, I was doing an impact analysis in LS-DYNA Workbench. I am giving pressure value to a rod to impact outer body. However, when I add velocity the model works truly. When I add pressure bodies penetrate. I checked the contacts. I am using keywords and I am sure that they are correct. What can be the problem?
September 23, 2025 at 7:33 pm
Alex R.
Ansys EmployeeHello Elif,Â
Is there a significant difference in impact velocity between these two cases? Could you please share your contact parameters? Also, are you using mass scaling?
Thank you,
Alex -
September 24, 2025 at 12:31 pm
elif.cayiroz
SubscriberHi Alex,
There is no significant difference between 2 cases' impact velocity. I am not using mass scaling. I cannot directly share my contacts but I am using program controlled formulation for my both bonded and frictionless contacts.Â
3932
1414
1272
1119
1015
