March 31, 2021 at 5:56 am
panlicheng
SubscriberI use the default settings for meshing, and will not report an error, but the solution result is not correct. I think it's a problem with the grid. After encrypting it locally, an error appears, as shown in the title.This is the first error.And the second one is "An error occurred inside the SOLVER module:general error."What's wrong with it? Thanks!
March 31, 2021 at 12:45 pmMissy Ji
Ansys EmployeeFor the meshing error, can you all tet mesh, see if it goes away, for the second error message, can you open the file named messag, see what is the exact LsDyna error message is?nMarch 31, 2021 at 2:04 pmpanlicheng
SubscriberFor the meshing error, can you all tet mesh, see if it goes away, for the second error message, can you open the file named messag, see what is the exact LsDyna error message is?/forum/discussion/comment/113485#Comment_113485
@mji, nThank you for your answer.Tet mesh dosen't work. The second error is :nAnd my problem now is that I used the default setting to solve the problem,although the result is incorrect.I want to encrypt the grid to get the right result but failed, there will be an error, and now the default grid can't solve the problem.I don't know how to mesh.n
Viewing 2 reply threads- The topic ‘(LS-DYNA) error:Pyramid elements have been detected.How to solve it?’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- LS-DYNA Installation Issues with Student Workbench 2024 R2
- Cross-coupled stiffness elements in LS-DYNA
- Initial Velocity Generation
- Initial Stress Shell Application and HistVarCosine in LS-DYNA
- MAT072R3- concrete damage rel3 validation
- shape memory alloy material in LS-DYNA
- *** Error 40058 (SOL+58) retractor 1000002:convergence failure at time1.01E+02
- LS-Dyna, Negative volume problem.
- Mohr_Coulomb material model (MAT_173)
- Fluid-structure interaction coupling
Top Contributors-
1927
823
599
591
366
